07 trx400 oil drain bolt housing cracked
basmn
We had a member that had this problem.  It’s a tough call working with this sort of thing.
JB well does work but it’s not a permanent fix by any means.   There are secondary drain plugs you can install that get installed and they have another drain plug that’s within the new plug. Much smaller hole but it works.  You could install that and carefully thread it in with high heat silicone.  That should hold on for a while but you have to constantly check it.
Second way to do it is have a good heli arc welder weld the cracks and maybe re tap it.
Hey Bro I used these myself on spark plugs that got striped out and never had a problem so thing I go this route over the JB weld any time.I used it ti in crazy places always worked but if you lost the oil that work but the end if it.
Good luck hope it works for ever what route you choose buy heli coil is very safe and no real pressure on it either like a spark plug has
  • 10 months later...
    • By killerklown
      I received an additional parts engine with a 220 Bayou I purchased, but I believe it's a couple years newer than the ATV, Is there a way to decode the engine serial number like we can with VIN numbers?
    • By Chucksta
      Any ideas?
    • By drag_on
      after the gully wash i dont know if its such a good idea to go
    • By mga
      I just saw a video on TikTok where some guy took the rear end off an ATV and bolted on a roto tiller in place of rear wheels. I wish i saved that video to post here....good thing it was 4 wheel drive...lol but, it seemed to work.
      I'm not sure how he made it bolt on to the drive....
