Hi all.
New to the world of quads. Recently got a Basham 200cc.
I am expecting a problem with road stability. When I get up to anything above 30mph on any road the bike will randomly pull either, into the left or right and I have to constantly fight to keep the thing straight. It’s totally unpredictable and have had a couple of close calls. I have checked play in the steering, ball joints, wheels, tyre pressure etc. Can’t figure out what’s causing it. I’ve speculated that the road camber May have something to do with it but like I mentioned I’m new to the quad world and maybe this is normal but any advice anyone can provide would be greatly appreciated as at the moment I’m too nervous to take it out on the road.
Thanks.
When you say road are you referring to asphalt ?
Quad stability on open roads like asphalt are not really in my opinion stable in any circumstance.  Nothing is high speed balanced like a car tire would be.  So in my experience bikes I’ve ridden on asphalt always have pulled one way or another.
Your bike however may have a lighter front end which results in the front end coming up a bit when you accelerate.
Try to swap the front tires and see if the condition reverses and pulls the other way. Is one tire worn more then the other ?
Take a good look at the frame to see that it was never crashed and repaired like welding work done etc.   look at the shocks and see that there’s are compressing properly.
Things perform differently at higher speeds.
    • By DrtyGrlKristin
    • By MikeDB
      Greetings to all.  New to the forum, but not to ATVing.  I started when they only had 3 wheels!  Getting back into riding.  Polaris 850.  Too many bells and whistles, but what do you do.  Scouting out places to ride legally now.
    • By vaneleus
      New member.
      Have a few hondas:
      2007 Recon
      2008 Foreman
      2002 Rancher
      2014 TRX90X
      Found the place looking for a service manual for the Recon.
    • By USRaider
      Hello all!
      Kept indoors but hasn't been run in 5 years.  We're not trying the engine until the gas is replaced, and the tires are reinflated. But the previous owner said their only issue was stalling when shifting to reverse without giving some throttle.
      I'm optimistic!  See y'all around!
