Wiring for my 2002 Polaris Scrambler 90
By mattgoodwin
I'm repairing a 96 Timberwolf 2x4. Many years ago a dog chewed the wires that go from stator to the rectifier/regulator, and I've had to use the pull start ever since. Ive since lost the plug for the stator and on the wiring harness side. I'm ordering a new stator that will also come with the female plug that I need to fix it on the wiring harness side, but I have no clue in what position to put those 3 white wires(ones I'm holding with electrical tape on them) back into the new plug. Since they're all the same color, does it matter? Any info on this or pictures anyone has of their own will be very much appreciated.
By anthonyd256
By picriver
new ignition switch
four wires - green, red black, black with white line
atv four wires - pink, pink with white line, black, red
which is attached to which, please and thank you?
By Norseman69
Hi. I just bought an lt230 1993. Ive started buying parts for a full rebuild. But somehow beskepedal has been removed and pegs welded to where They are supposed to be screwed. I was wondering if anyone have one and Could measure how far out the pegs are. Like the peg the brake is put on and then peg outside of it. And the one lower down. So i can recreate them.
