Hello all just recently acquired this atv which as you can see in the pics that it has had an unsheltered life. i did get it running and put some used tires on the front.
It still needs a bit more well needed maintenance, chains tightened and oiled. needs an airbox or air cleaner and other misc items.
Hay @Travis Mitchel welcome to Quadcrazy!
Nice bike you found there.  First picture without the gas tank plastic ? Second pic with it on ? The bike looks in tact.  If that bike was sitting out in the elements and the kill switch and ignition aren’t working it may be a matter of just cleaning the contacts and adding a little dialectic grease spray on them. If not then maybe you have to see if the wiring was messed with.
 I like the older bikes!! You can do whatever you want to them and it only makes it better.   A little sanding and some spray paint and that bike will look great.
How did you come across it and how does it run aside from the kill switch issue ?
    • By jhamrick75
    • By oxidized_black
      1981 - 2008 ATV HISTORY
      1986 - 2006 Kawasaki KLF300 Bayou service manual
      1988 - 2002 Kawasaki Bayou 220 service manual
      1994 Kawasaki Bayou 220 Owner's Manual
      1997 - 2002 Kawasaki Prairie 400 service manual
      2003 - 2005 Kawasaki KLF250 Bayou service manual
      2003 Kawasaki KVF360 Prairie service manual
      2004 Kawasaki KFX700 V Force service manual
      2004 Kawasaki KVF700 service manual
      2005 Kawasaki KVF750 Brute Force service manual
      2006 Kawasaki KFX80 Specs
      2008 - 2009 Kawasaki KVF750 Parts Manual
      2008 Kawasaki KFX450R service manual
      2008 Kawasaki KVF750 Brute Force service manual
      Please visit the downloads section at https://www.quadcrazy.com/files/
      Are the cheap tires from Amazon any good? I know nothing last forever, but don’t want them to dry rot in a year.
