I just sold my mildly built blaster and am about to buy an 84 atc250r I'd like it to be a modded banshee killer. I already plan on a port and polish and possibly a head shave. It's going to pretty much be a full drag build. I'd like it to stay stock bore but I can change it if necessary. What parts should I plan on ordering to get the most bang for my buck. I can do all the work myself so that should cut costs quite a bit. (hopefully)
    • By Rick Shropshire
      I’m looking at replacing rear brake calipers on both of my blasters. I was told that the only thing available was a hydraulic upgrade? I’d prefer the original. Anyone?
    • By Baldwin
      I’m brand new to 4 wheelers and just bought a 1987 Yamaha Moto-4 350 4X4 to use for hunting. I say 1987, but not positive. The owner is not positive about the model year, but he said 1987 sounds about right. He also gave me his son's Clymer manual that covers 1987-1999. The frame has rusted just enough that the full serial number is no longer readable. I can read some numbers/letters, but it is spotty. Anyone know how to determine model and year if you cannot read the serial number? I have included photos.
      So it started fine when I got it home, but it would only stay running if the choke was open even when warmed up. No identification numbers are stamped on my Mikuni carb to determine specific model. The choke is controlled by cable connection on dash, so it is not a model that has the choke lever right on side of carb. Since it would only start and run with choke open, I decided to rebuild the carb using the OEM rebuild kit. Took it apart, cleaned jets, orifices, replaced o-rings, gaskets, etc. After reinstalling the carb, the engine will still only run with choke open, but now the engine sounds like it wants to shut off and there is a consistent low volume backfire from the muffler. If I rev the engine, it sounds better, but still continues backfiring.
      The fuel screw was seated at 2.5 full turns before I cleaned it so I put it back at that setting.
      I’ve looked high and low trying to find a video of someone rebuilding my specific carb, but it appears there are many variations. Appreciate any guidance to get it back to running like it should. I have included photos.
      Any guidance on figuring out model year would be greatly appreciated.
      Thanks for your time.
    • By 86ccord
      Starting this build thread to keep up with everything on my build and hope to motivate someone!
      I picked up this 2008 Yamaha Big Bear 250 2 weeks ago. A guy that I hunt with parked it at the hunt club for a year or so before I asked him if he wanted to sell. He said " fill my feeder and throw some batteries in my cameras, and you can have it". Sounds like a deal to me!
      I have attached some pictures of how it sat under a tarp in the woods and when I got it home and cleaned up a little.
    • By Whiterabbit
      3500lb, synthetic rope lead and everything needed to install for........................................ $89 bucks!  I'm installing one on my '01 Bombardier Quest and it looks like a legit buy. If you have a RK nearby & you need a winch you might want to swing by before they disappear.
