I have a go kart with a 150cc gy6 engine it will run great and rev when i have the rear tires off the ground but as soon as i try to drive it it boggs down and doesn't move i cleaned the carb and fixed a small vacum leak and it still does it., Any ideas on what it could be?
@GrizzlyRider the carb is set up within spec, the fuel shut off/pump is working great. it has a cvt clutch with a foreward reverse transmission and chain drive from that to the axle. it was having trouble shifting from neutral or reverse to drive so i opened the trans manually put it in drive and took the shift fork out, but i can easily spin the transmission by hand.
so if you aren't getting torque from the engine to move the tranny and it bogs down its air, fuel, spark (engine) related. If you are an the transmission isn't engaging you may have a tranny/clutch problem. If in neutral it revs up without issue, and then you manually put in in drive and it bogs down...someting is up with the tranny holding it back. When in drive does the chain/rear axle move at all?
I think you have a variator issue if it runs fine when jacked up and boggs down when sitting on the ground your variator is stuck in high gear mode , a thorough revision on the variator weights and proper belt positioning should solve your problem also check rear clutch spring is in good condition they often brake causing the problem you describe Please keep me posted Good luck!!
    • By Shorty51
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By quadnut20
      Looking at replacing tires on my 2003 Foreman and was seeing what everyone is recommending fore it ?? Its mostly a plow machine but in the summer the  kids take it out !!
    • By digrig
      Hey everyone,
