By HoldenBoy
By wilmpie
hi everybody
I have a kymco mxu 250 automatic from 2006 250 cc that keeps going forwards or backwards when i shift backwards or forwards an then shift to neutral .
thanx in advance
By harryjr
By BillR94
Thank you for your time
Bill
By T37Mark
