My ranger crew 700 is hard to shift and gets locked into forward. When trying to shift into reverse we have to shut engine off. Shift then restart. Checked linkage and gears are fine. The RPMs arent really that high but did notice a little improvement when we lowered it. Did notice the throttle cable looks damaged. Could this be the issue?
If the throttle cable is damaged and lowering the throttle helped I would say yes this is an issue.  Lower the idle as low as it can go without stalling and see how it shifts. Should idle at about 800 to 900 max rpm.
Thank you all. We ordered a new throttle cable because it looked like the end was damaged.  When we replaced it though we had trouble getting the RPMs to stay at one setting. They kept jumping all over. Adjust to 900 and would jump to 1000 and 1100. After fighting with it we think we have it now. Seems to be shifting fine now.
  • 2 years later...
out of 3 choices for not shifting my rpms are in the area that people said 1100 area so thinking of checking belt. I don’t no about the throttle cable haven’t looked for where it is located and where it runs
    • By flyinbrian365
      What's Covered:
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
    • By jeffrocdx
    • By sandman001
      any ideas how to correct
