I installed a new China made carb months ago. So far all is well.  This carb has a heater, while the original did notI never considered hooking it up.  Here in far N. Ga,  0 deg. is about the coldest it normally gets in a bad winter. Should I bother hooking the heater up and will it need a sensor or just an off/on toggle switch? Totally new subject to me.
Meh. Your choice. I wouldn't bother since its not that cold in the south but its a neat feature that supposedly makes it start and idle a bit easier in cold weather. Probably a necessity in the far north.
I don’t think it would advantageous to do that since the harness does not have that feature built in. The heater comes on based off of a thermostatic sensor that tells it to turn on and off.  It’s manageable to do and could be done I guess  but it’s prob not worth the effort especially based on where you live.
    • By HoldenBoy
      Hi all,
    • By sunn
      Anyone with experience on relocating the miniscule battery from the front lower center wheel area to the left rear wheel area on the Polaris Sportsman 570?
    • By DemonQuad666
      I'm sure this has been tossed around on here numerous times but with the unveiling of the new KTM fuel injected 2 stroke. Could this be the first step in a come back for my beloved double ding ding machines. Ok lets hear it. Why do you like one or the other??? Myself, I always felt it was the throttle control and Powerband response with the 2 strokes. I know this sounds weird but on a 4 stroke, no matter size or model. I always felt like i was along for the ride instead of in control. I've spent hours on my buds 400EX, even took a new 450r for a spin. before they discontinued them. Blasters, Banshees, and a number of 125's, 250's and even one late 80's Honda XR250R... Results all the same. For me its a comfort and control that im used to with the 2 strokes.... and i love the smell of bean oil... So lets hear it. Im sick of arguing with same two people at work on this issue.
    • By qcm413
      Hi,
      thank in advance
    • By heath
