I bought a 2003 Recon from a kid that beat it – all plastics cracked etc, When I replaced the rear brake the inside – axle, rear oil  - were clean and in good shape, so I think Honda won the kid vs quad battle.
It shifts a little clunky (I made the adjustment) and after riding for a while I get a hot friction material smell I wonder if he used the wrong oil and if any damage was done.
Thanks Frank
I believe it was there before, but I'll back off the rear brakes and see what happens.
How would an auto  oil affect the Honda clutch ?
No i don’t think you would get an odor based on the fact it’s internal but the engines have breathers so you might. I’m just not 100 percent sure. I know the clutch wont act right and you will feel a slip.
Edited by Frank Angerano
  • Admin changed the title to 2003 Honda Recon friction material smell
    • By TomJulio
    • By vaneleus
    • By gordonmacritchie
      all fuses are fine
    • By cruteg8
      I was thinking about trying to repair some cracks in the plastics of a Lakota Sport i just purchased has anyone ever tried (U.S. Chemical & Plastics USC GarageTM Flexible Glaze USC-77704 it) https://www.ebay.com/itm/364866165725. i was thinking jb weld for plastic then using this as a bondo that can be sanded smooth
