I have a 2000 Polaris Xplorer with the 250 two stroke motor
It does not want to start with the electric start, the motor cranks fast, the battery is good, and there is good spark when cranking. The engine starts perfect when using the pull cord, it even starts if I pull the cord slowly and starts with one pull. The engine idles smoothly once started. My wife says she needs the electric start to work.
You'll  have to  trace out the wiring on it . There  is a safety switch  or relay not working in the ignition  circuit.  I  would guess  most likely  a relay or possible broken wire  since  it  turns over  on the starter.  Usually  when safety  switches  fail  the  starter  also will  not  spin.  It is not  getting  power to run  when the  start  relay is energized  so  start there  after  checking for an  obvious broken wire.
I put a OTC spark tester on the spark plug lead and had good blue spark, then I used my adjustable spark tester and found the electric start would produce a max of 1/4 spark jump, the pull cord would max at 3/8 jump. Then I installed a new spark plug non resister type and lowered the gap to 0.020 and it still would not run with electric start but still starts fine with pull cord.
    • By realpilot
    • By 88bigbear
    • By cfherrman
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By OldATVowner
