whats up fellas....the white wire going from the throttle body came unplugged from the circuit  board and im not sure where it plugs back in to ? i see where the red wire goes but im not sure where the white wire goes...im not even sure what those wires do..any help would be appreciated..thanks. 1996 polaris sportsman 500 4x4 push button awd.
Sorry I was working all day give me a little bit and I will try and help you sort it out.
If you look at the photo with the diagram it shows a ETC switch and an AWD switch. The ETC matches the color code wires  you mentioned and goes back to the hub safety switch. I would start by tracing the wires from the handlebars and work your way down to the controller and the to the hub solenoids.
Locate that hub switch and there should be a white wire coming off of it. That white wire goes to the handle bar switch.
That white wire you are holding might be coming from the hub switch.   So start there and trace it back.
    • By crankin
    • By Zrach
      I wanted to share a successful workaround for a "no-spark" issue on a 2009 LT-A400.
      This is specifically for cases where the CDI has been diagnosed as faulty, but the age or condition of the machine makes the cost of a brand-new OEM unit hard to justify.
      Note: This modification compromises the factory “no-start” circuits.
      On some malfunctioning CDI units the internally damaged circuitry is only partial.
      Feeding full time power to the Parking Brake pin, the unit is triggered to bypass the internal fault and produce a healthy consistent output to the Ignition coil.
      The Modification
      See the second diagram attached below for the wiring specifics.
      The Result:
      The machine has clocked over 1,000km since this repair and is still running strong with no ignition dropouts.
      ⚠️ IMPORTANT SAFETY WARNING ⚠️
      Please be aware that this modification compromises the factory safety "no-start" circuits.
      The machine will now start in gear. The safety interlock involving the handbrake is no longer functional. The machine can move unexpectedly if the starter is pressed while in gear. Proceed at your own risk. If you sell the machine or let others ride it, ensure they are fully aware that these factory safety buffers have been removed.
      Faulty CDI Workaround.pdf
    • By 97kingquad
    • By fwsamm
    • By Does_This_Look_Bent?
      Hey everyone, I just replaced the carp on my 98 Kodiak 400 with PN#4SH-14101-00-00. It starts and idles perfect, but once it’s good and warmed up, it bogs out at 3/4 throttle or more… it sounds like it’s bouncing off a rev limiter haha… I tried the air fuel screw, all the way in and out 2-1/2, and it made it a touch better… tried 2 turns and no different. Am I missing something?
