1996 polaris sportsman 500 throttle body wires
Eddie Rahm
whats up fellas....the white wire going from the throttle body came unplugged from the circuit  board and im not sure where it plugs back in to ? i see where the red wire goes but im not sure where the white wire goes...im not even sure what those wires do..any help would be appreciated..thanks. 1996 polaris sportsman 500 4x4 push button awd.
Sorry I was working all day give me a little bit and I will try and help you sort it out.
If you look at the photo with the diagram it shows a ETC switch and an AWD switch. The ETC matches the color code wires  you mentioned and goes back to the hub safety switch. I would start by tracing the wires from the handlebars and work your way down to the controller and the to the hub solenoids.
    • By utvboard
      2009 HONDA BIG RED
      Big Red
      KEY FEATURES
      2009 Honda Big Red in Camo
    • By Drillbit
      Hey all,
      Thanks!
    • By Uglyside38
      Has anyone had any luck converting an older quad from a 7 wire CDI to the newer (and cheaper) 5 wire CDI?
      I have a 1988 Suzuki Quadrunner and I believe the CDI is on it's way out...🤦🏼‍♂️ A used CDI from 1988 goes for $250-$300 on the bay...and that's when you find them. The Chinese CDIs for the 1990 and up quadrunner are only about $40. I have read a blog from a guy who says it's possible and that 2 of the wires can be omitted if the rectifier is a newer one also. Any experience with this would be greatly appreciated!!!🤙
    • By 97kingquad
    • By alexwv1863
      Hey everyone, I have an issue with my dad's 03 Yamaha Kodiak 400. It had been running great but he left it sitting for a short amount of time. When he started it, it ran fine for a little bit but all of a sudden it quit taking gas. I thought it may have been the carb because it him not running it. The carb ended up being pretty clean. He put it back on and after taking it off and cleaning again, I'm beginning to wonder what it could be. It'll start and idle just fine, but when you go to give it throttle, it'll die out. It sounds like it's not getting air right but idk where to look or what else it could be. I'm stumped and need to figure this out before I go crazy. Anyone have any ideas???
