Hey Barry, welcome to Quadcrazy!
The cluster on the dash should have nothing to do with the high/low beams.
If the cluster is working properly aside from the illuminating portion then there may be a problem internally with the cluster. I would move some wires around going into the cluster and see if it comes on like a loose connection.  I am not 100% sure but my guess would be if the cluster has power and shows the diagnostic portion (mph/rpm) of the atv and  the illumination portion should work as well.
Hey Frank! Thanks for the reply!  Sorry I didn't state there is no illumination on the cluster at all, no diagnostic display at all.  Just assuming the key turned on allowing the lights to turn on means I'm getting power to the pod? ]
I moved this unit from one garage bay to the another garage this morning it was fine, went back in an hour or so to move it back and it did this.  I can't grasp what the issue is.....possibly a ground issue?
It could be a ground issue or a corroded fuse. I would go get some dielectric grease and start taking plugs and fuses apart, clean all areas and apply the grease and reconnect.    Some plugs may be tough to get to since they are located under the front plastic right where that cluster is located so you may have to pull that plastic off.
    • By flyinbrian365
      What's Covered:
      Topics covered include:
      AWD and differential repair
      Brake system service
      Popular related searches:
      Sportsman 570 wiring diagram
      Sportsman 1000 wiring diagram
      View File 2020-2026 Polaris Sportsman XP 1000 S service manual
      Download the 2020-2026 Polaris Sportsman XP 1000 S service manual PDF for complete factory repair, maintenance, troubleshooting, and diagnostic procedures. This comprehensive Polaris Sportsman XP 1000 S repair manual covers all major systems including engine service, EFI fuel injection, clutch and transmission repair, AWD drivetrain systems, suspension, steering, brakes, electrical troubleshooting, wiring diagrams, torque specifications, and factory maintenance schedules.
      Designed for ATV owners, mechanics, mud riders, trail riders, and DIY enthusiasts, this factory-style service manual provides detailed step-by-step instructions and diagrams for maintaining, repairing, and rebuilding the Polaris Sportsman XP 1000 S high-performance utility sport ATV.
      Polaris Sportsman XP 1000 S engine repair
      AWD and differential service
      Suspension and steering repair
      Brake system maintenance
      Oil change procedures and maintenance schedules
      2020 Polaris Sportsman XP 1000 S service manual PDF
      Sportsman XP 1000 S wiring diagram
      Sportsman XP 1000 S maintenance schedule
      This Polaris factory repair manual is ideal for riders looking to maintain, troubleshoot, repair, or upgrade their Sportsman XP 1000 S for trail riding, mud riding, hunting, utility work, and extreme off-road performance.
