Why is it important to have an ATV Winch you may ask? If your ATV gets stuck in the mud, you can attach the winch cable or rope from your ATV winch to lets say a nearby tree, or something else that can act like a large anchor, to then pull yourself out. You can also help get your friend's ATV out of the mud if they get stuck, and be a hero! It's also a must have in the winter, if you have a plow...
An ATV winch is a must have accessory for most 4WD ATVs, especially if you plan on riding in areas where you may get stuck or need to help a buddy out of a pit. Sure an ATV tow rope might work for that, but it sure is nice to have a winch ready to go and provide that pulling power when needed. If you are debating a synthetic line vs steel cable, read up on the difference, pros, and cons of each. We have an article explaining some of this from a few years back here. Some 2WD utility quads can also make use of a winch. In most cases a 1500lb ATV winch is just fine. If you are moving up to some of the larger ATVs and UTVs and want more power, you can move up to a 2,000lb or 3,500lb winch, depends on what you want to spend really. There are a few good buys under $100 you can find on Amazon today, that will get you going. We wanted to showcase and share a few of these with you.
CASTOOL Electric Winch 12 V Recovery ATV/UTV Winch Kits Wire Remote Control 3000LBS Capacity
  • Easy Handling And Comfortable Use With Remote Control, Take-up And Release The Rope Automatically
  • Prepared For Mounting Onto a Vehicle Building Boat ATV etc. Permanent Magnet Motor Draws Less Current, Idea For ATV Use
  • 3000lb 12 V Winch With Reliable Engine incl. Overheat Shutoff Strong Steel Cable Compare Others 6000LBS , Mounting Kit And Plugs Plus Remote Inclusive
  • Single-Stage Planetary Gear System For Fast Line Speed
  • Automatic Load-Holding Brake For Maximum Safety,More Convenience And Secure
  • Steel Cable and Hook
  • Currently $98.99 on Amazon
ORCISH 12V 3500lb Electric Winch ATV UTV Synthetic Rope Winch Kits
  • Comes with 2PCS Remote Wireless Control +1 pair of gloves
  • A good quality hook and 4-way roller fairlead
  • 3 stage planetary gearing system
  • Specially designed for ATV,Corrosion resistant
  • Sealed low amperage permanent magnet motor
  • Currently $99.90 on Amazon
  • Get the steel cable version for $88.99
Offroad Boar 3500Lbs Electric Winch for ATV/UTV Boat (Stainless Steel)
  • Comes with a good quality hook and 4-way roller fairlead
  • Free spooling clutch for fast Steel Wire Rope payout
  • Currently on Amazon for $88.90
Its also worth noting that ebay has a few ATV winches under $100 you can check out as well. Some of these are:
ebay ATV Winches
ebay atv winches
NOTE: The ORCISH is the same price on ebay as it is on Amazon
There was also a pretty good $100 rebate from Warn, but that ended in May. Be on the lookout for manufacturer rebates and search online for deals. If you see some good deals under $100, please post in our comments. 🤑
Buy ATV Winch
ADD WARN RED TO YOUR BLACK FRIDAY
From now until Dec. 2, 2019 you can get the best deals of the season on WARN items from our website. From winches to bumpers; rigging equipment to a selection of our Epic Trail Gear bags, you'll find a host of premium WARN goods on sale for a limited time. So whether you're looking for the most durable products for your truck/SUV, or that just-right accessory for an ATV/Side x Side, you'll save some green when you're buying WARN red during our Black Friday Sale!
To view the deals, visit warn.com and get ready to GO PREPARED this holiday season.
To add to the thread here... Also under $100 are several versions of Champion winches.  They are complete garbage so don't bother.  The one on my son's 420 lasted 3 rides and the 3rd only happened after working the spool over a couple times.  Of course, his is a Honda boat so that doesn't help.
Trying one of Harbor Freight's finest today, we'll see how that works out.
i have a Badland 3500 wench on my 2020 Forman 520 which i had on my 2018 alterra 500 and i have beat on it pretty hard and not once have i had a problem. had for 3 yrs and paid $109 with a coupon.
I tried synthetic cable on it and it was horrible so i bought the steel cable to put back on it. It mounted to the very front of my quad too and has no protection from anything.
I don't see this one lasting long but hopeful. His 420 and my 300 spend as much time being a submarine as they do an ATV and most winches won't do well under water. I really HATE the wireless remote and removable control on the Badlands winches but they're cheap enough. A simple rocker switch lasts forever but the wireless remote I don't see lasting long
  • 2 years later...
    • By sandman001
      This 2006 ArticCat dvx400 didn't have a reverse cable. I got one and am wondering how it routes? If someone has a dvx400, could post a pic of there reverse cable routing, it would be greatly appreciated. Thanks
    • By Tim Keiper
      For ATV and UTV enthusiasts, regular maintenance is key to ensuring the longevity and performance of your vehicle. One of the most overlooked yet essential components is the battery. Just like in cars, ATVs and UTVs require a reliable power source to start the engine and power additional features like lights, winches, and electronic accessories. Understanding why changing your ATV and UTV battery at the right time is essential—and why Weize batteries are a top choice—can keep you out on the trails longer and reduce the risk of unexpected battery failures.
      Why Changing Your ATV/UTV battery is Crucial
      1. Prevent Unexpected Breakdowns
      Imagine being out in the wilderness, far from help, and suddenly your ATV won’t start. A reliable battery ensures that your vehicle can always start up, keeping you safe and ready for any situation. Old or degraded batteries lose their capacity to hold a charge, increasing the likelihood of sudden, inconvenient breakdowns.
      2. Improve Overall Performance
      A fresh battery doesn’t just guarantee startup; it also supports optimal performance. ATV and UTV batteries power important accessories, such as headlights, which are crucial for visibility in low-light conditions. A weak battery can dim your lights, affect the functioning of electric winches, and even disrupt GPS or other electronic equipment. A new, high-quality battery helps maintain the consistent power output necessary for these essential features.
      3. Extend the Life of Other Components
      An aging battery can strain other vehicle components. As the battery weakens, it requires more effort from the alternator and other electrical parts to maintain a charge. This added stress can wear down the electrical system over time. Replacing the battery on schedule can help to reduce strain on the alternator and prevent more costly repairs down the line.
      4. Adapt to Changing Seasons
      Temperature fluctuations can significantly impact battery life. Colder temperatures reduce battery efficiency, which can lead to issues during winter months, while extreme heat can cause rapid battery degradation. Changing your battery seasonally or before long periods of extreme weather can help avoid seasonal breakdowns and extend battery life.
      Why Choose Weize batteries for Your ATV or UTV?
      When it comes to replacement batteries, Weize is a top choice among ATV and UTV enthusiasts. Here’s why Weize batteries are particularly suitable for powering these rugged vehicles:
      1. Exceptional Durability
      Weize batteries are designed to withstand tough conditions, including off-road terrain, shock, and vibration. Whether you’re tackling rocky trails, mud, or hills, Weize batteries are built to last. Their rugged construction helps to ensure reliable performance even under the most challenging conditions.
      2. Long-Lasting Power
      Weize batteries use high-quality materials that allow for a stable charge and dependable discharge rate. This long-lasting power translates into fewer replacements, saving you money over the long run. Weize batteries are built to provide reliable starting power and can handle additional loads from accessories, ensuring that your ATV or UTV gets all the energy it needs.
      3. Low Maintenance and Easy Installation
      Weize batteries are designed with a focus on low maintenance and easy installation. Many models come pre-charged and sealed, meaning they’re ready to use right out of the box. This ease of installation makes them an ideal choice for riders who prefer a straightforward setup with minimal hassle.
      4. Affordability and Value
      Weize offers high-quality batteries at competitive prices, making them a great value for ATV and UTV owners. Despite their affordability, they don’t compromise on durability or performance, providing excellent quality without the premium price tag.
      5. Environmentally Responsible
      Weize prioritizes sustainable manufacturing practices, ensuring that their batteries meet environmental standards. This focus on eco-friendly production is a plus for ATV and UTV riders who want to reduce their impact on the environment while still enjoying high-quality equipment.
      Signs It’s Time to Change Your battery
      To maximize your ATV or UTV’s performance, be aware of the signs indicating that a battery replacement is necessary:
      Slow Engine Crank: If your engine takes longer than usual to start, it may be due to a weakening battery. Dim Lights: Dimming headlights are often a clear sign that your battery is losing its capacity to hold a charge. Frequent Recharging: If you find yourself recharging the battery frequently, it might be time for a new one. Age of the Battery: Most ATV and UTV batteries last between two to four years. Regular replacements can prevent unexpected breakdowns. Final Thoughts
      Changing your ATV or UTV battery when it shows signs of wear is essential for reliable performance and safety on every ride. Choosing a dependable brand like Weize ensures that you’re investing in long-lasting power, durability, and value. With a new Weize battery, your ATV or UTV will be ready for every adventure—whether you’re out on the trail or tackling heavy-duty tasks. So before you embark on your next journey, make sure your battery is up to the challenge, and consider Weize as a trusted choice for dependable power.
    • By drag_on
      I have 3 atv's 2 have winches , the problem I sometime have is loading onto the trailer if the bed is wet or of frosty. there have been times the winch is needed. but , what to do if the w/o ATV  or any other perhaps dead ride needs to go onto the trailer . 99.5%  of it came from harbor fright.
    • By TravisCr
      I have a 2003 Polaris Sportsman 700 I bought to use a Polaris plow with- it came with the plow and a winch attached to it (rebranded little warn), the wires from the ATV kept coming disconnected- so I bought a new old stock Polaris/Warn mount and did the same with a 2500 Warn- Was that a good idea? Or should I have gone with something like a Harbor Freight (I love to hate this company but some of their products are decent)
      Is there anyone else Out there I should have considered or was this my best choice-
      I've done a lot of "jeep" stuff but just getting into the quad thing a bit more.
      Thanks in advance.
