Hi all just started to mount a winch on my kingquad 400 using a kfi mounting plate and the holes don’t line up. The winch is Rhino 3000lb not sure if you have them in the States they’re an Amazon job. I was wondering can I just drill the mount out to make it fit, the holes are fine depth wise it’s just the width trouble is it’s not out a great deal and as the holes are countersunk they will overlap I don’t want a loose winch. Dunno if you can make sense of all that but any help would be appreciated thanks.
Hi thanks for replies it’s got a switch and Two wireless remotes. It’s a different brand to D Rhino I think it’s a UK based company obviously not made there as they are fairly cheap it seems a nice solid unit.
Haven’t tried it out yet but will let you all know how I get on.
    • By Otter9099
    • By captnunu
      I have a 2007 kingquad 450 fuel injection. I try to start it with the hand crank and almost flip over the quad. I have taken the hand crank off and cleaned it but this did not fix the problem. I believe there is a decompression valve that is supposed to engage when pulling it over by hand. How can I check this?
    • By kingkw
      I have a Harbor Freight tire changer. I could not get the tires off the rim.
    • By Zrach
      I wanted to share a successful workaround for a "no-spark" issue on a 2009 LT-A400.
      This is specifically for cases where the CDI has been diagnosed as faulty, but the age or condition of the machine makes the cost of a brand-new OEM unit hard to justify.
      Note: This modification compromises the factory “no-start” circuits.
      On some malfunctioning CDI units the internally damaged circuitry is only partial.
      Feeding full time power to the Parking Brake pin, the unit is triggered to bypass the internal fault and produce a healthy consistent output to the Ignition coil.
      The Modification
      See the second diagram attached below for the wiring specifics.
      The Result:
      The machine has clocked over 1,000km since this repair and is still running strong with no ignition dropouts.
      ⚠️ IMPORTANT SAFETY WARNING ⚠️
      Please be aware that this modification compromises the factory safety "no-start" circuits.
      The machine will now start in gear. The safety interlock involving the handbrake is no longer functional. The machine can move unexpectedly if the starter is pressed while in gear. Proceed at your own risk. If you sell the machine or let others ride it, ensure they are fully aware that these factory safety buffers have been removed.
      Faulty CDI Workaround.pdf
    • By Joeguy
      I randomly got the urge to rebuild my quad and seem to have lost my nuts and washers for mounting the head somehow. Has anyone replaced them with just some normal hardware from a local store and had luck? Really im just worried about the washer thickness and the depth of the acorn cap nuts.  I found some used sets on ebay but they want like 20+ dollars for em and then id have to wait for shipping aswell, trying to get it done before we get too much snow.
      I am also just going to keep looking around as i know i have seen them recently, i just must have moved them to keep em safe one day and forgot where i stuck em.
