Rifle mounting on ATV
By Callaway
By McG75
Sorry I suck at these forums so if you see this submitted under update status, my bad. Anyhow this is a new shock for a 96 Yamaha Kodiak 400 4x4 it fits my 96 Yamaha Timberwolf 250 4x4 perfectly. Little narrower are the bottom than the original but everything else is perfect. I extended it to almost a half in from full extension because I’m pushing 350 pounds. It rides and hold me well. So if any of y'allRace driven shock. have been looking for one and didn’t want to do the research here it is.
By p5200
Anyone have any ideas how I could remove this drain plug from the front hub it's a little below the surface.
By Quadman11
Hi Guys, First post.
I'm Having an issue with my KLF300 2X4.
Just purchased a 2000 model KLF300, when i first rode is i noticed the gear shifting from reverse to first and vice versa was extremely hard and stiff.
Now When the bike is running it is Shifting straight past neutral into reverse without using reverse lever, making neutral impossible to find. Also the neutral light and revese light has stopped working. To get the bike started i grounded the green wire coming from the switch so now i can start it again but the shifting issue is still there.
I have adjusted the reverse lever and cable so that it is fully retracting but this hasn't changed anything.
Can anyone recommend anything to check etc?
Thank you.
