1997 Yamaha Big Bear 350 2WD Opinion's.
Similar Tagged Content
By diamonddogs
Hi i bought my first atv last week, mostly for plowing. its a 94 yamaha big bear 350 4x4, with plow, new front axles, carb rebuild and some other stuff for $900. in todays prices, i think it was a pretty good deal. I plan on tearing it down and doing a semi restoration in the summer. its been clearly neglected so i suspect i will need to do a fair amount.
couple questions.
1. parts and manuals, so far i know it needs front shocks, tie rods, brakes, cables, lots of small stuff, whats your guys favorite online atv parts store? where can i find a good repair manual?
2 - starts and drives great, shifts a bit hard? not sure whats normal because i dont have a point of referance. i have to almost lean back in the seat and lever my foot up to get it to shift, seems like there is either alot of play in something (shift lever itself is tight) or there is a long travel, or it just dosent want to shift. also the hi / low / reverse lever needs to go past the gate a bit to actually shift into gear, and seems to need me to shift into nutral before shifting into reverse (not sure what your supposed to do). also wondering a bit about the history of the machine, because the plastics have a slot for a dash mounted shifter, but the one on it is a gated shifter right above the pull starter.
3. seat and plastics repair, seat is quite torn up with a seat cover over it, plastics are pretty cracked up, these items i havent found replacements for for any reasonable price, i dont care a whole lot about asthetics but whats the best way to functionally repair these things? is there reasonably priced replacements somewhere? i plan to bedline the whole thing after im done.
4. there was no title, but i did get a bill of sale, will it be difficult to get it titled / registered? (im in mn)
thanks in advance for your help, looking forward to being part of the community
By hutchir3
Hello Folks....new to the forum. I have two Warriors (87 and 92), and an 89 Big Bear. Looking for some help with engine issues on the warrior, and my 89 Big bear backfired and died. Got spark, got gas, seems to have compression, (but haven't tested it yet...next). She rolls over good, maybe too good...seems soft. Have spark and enough compression to blow gas mist out the plug hole when cranking. Suggestions, Been running great since we got it.
By AKMichael
Hello All,
I have a 1999 Yamaha Big Bear 350 4x4 trying to get fixed up so my grandson can go out in the woods with me.
We have owned it over 10 years. It got harder to start, until it finally would not. Replaced the carb. Right afterwards, it started and ran nicely, but after turning it off, would not restart. Tonight I used starting fluid and ran, then died. Adjusted the idle up a little, used more starting fluid and ran great. It idled about 15 minutes. Turned it off, and restarted. Ran it around the yard about 5 minutes. Turned it off, and would not restart.
Any ideas or suggestions would be greatly appreciated!
Thank you.
By mike91
I’m just wondering what year bike i got? it seems the vin has been rubbed off i got it from a auction here in Australia engine starts but seems has a dirty carb wont idle well
and also has a problem I put it in gear and makes a grinding noise but does not move it the neutral light goes out but then when I change gear it grinds more in the higher gears as well I’m guessing the differential is stuffed so wanting to buy new part for it will start the pull down next week
this is the first bike I have worked on used to dealing with cars
Similar Topics
By Asen_77
Hi All,
My name is Asen and I am from Eastern Europe, Bulgaria. Riding a Yamaha Raptor 700R and this is my first Quad wanted for a vey long time :)
By Jride937
Have a 2002 Yamaha Bear tracker 250, everything was fine then one day just lost power. Battery is fine, have 12.53 volts coming out, but I have no lights no start no anything. Looking for a wiring diagram
By wiwild
Hello everyone !
I'm currently rebuilding my carburetor on my Yamaha moto 4 350 1987, first time I rebuild a carb 😅 ! It was leaking fuel from the overflow and inside the intake ....
When I took off needle (the platic top part was stuck like crazy) I had a spring and inside the kit there is a spring, an O-Ring and a washer.
Left is the needle that was in the carburetor and right is the new set (I already tried to mount it but it didn't felt right and I accidentally broke the o-ring)
Anyway, I saw in some videos and diagram that there is no spring in here. So should I put the spring back ? And where ? On top of the needle or bottom ?
This is an original Mikuni carb :
Thank you ! Also if you have any additionnal tips please feel free to share I want to learn the proper way !
By ATVNetwork
atvs The YFZ450R, Raptor 700R, and Raptor Sport quads are back!
Yamaha, the only major powersports manufacturer still producing sport ATVs, announces new 2021 YFZ450R and Raptor models. View the full article
By Samwise
Been out of the atv scene for a few years. Just bought a atv. Question I have. Is their anyone who makes a lithium battery for atv's. I only ask because they have them for boats now. Buddy of mine has 2 Dakota's he runs on his. I'd only imagine you can get a really strong battery at half the weight. Any input?
