Hey @Ellery Zandt welcome to Quadcrazy. FYI you should never post your email here. That line usually goes from the thermostat housing cover to a connection near the water pump. What its designed to do is allow some coolant to circulate through the system when the thermostat is closed. Its like a small bypass.
I'm not sure on the Kazuma but if you can post a few more pics of the water pump area maybe we can help you out.
Double check the reservoir for any connections, i doubt it bc its a pressurized system but you never know.
The only other way to check is to put a pump on the  radiator  cap. Put pressure in the system and see where you have coolant coming out.  You will have to block off the port on the thermostat housing with a piece of hose with a bolt in it. They sell a multi pump for all types of radiators at Harbor freight that pressurizes  the system to help find leaks. I am sorry but i am not familiar with the Kazuma brand.
I looked for the manual but don't see it in the library.
    • By tflack500tbx
      Background,
      Any Ideas?
    • By MadAdy73
      Hi there, can anybody share or link a PDF for the 1999 4x2 Quadrunner LT-F250 thanks.
    • By lindzjo
      Does anyone have a service manual for Qlink 700 atv.I cant find anything on one.Please help
    • By QuadDad22
      Picked up a 86’ LT 185 for $10 in trade value(my items only cost me $10)
      recoil only , I pull the recoil and it won’t move , so I took it off , I can spin the crank there one full turn left then it locks up , and one full turn back to the right and it locks up
      pulled the plug , the piston is moving up n down , both valves are moving(pulled the caps)
      pulled the clutch off , oil pump gear , and it still locks up after one turn
      any ideas or where to go from here would be greatly appreciated
      im a 2 stroke guy so this all is new to me
      thank you in advance y’all
    • By Kawiherder
      It starts and runs Ok but after a while the temp gage lights up and the fan fails to start.  Any suggestions on where to start looking would be helpful.  Thanks
