2004 ltz400 carburetor screw identification
That's the thing. I did remove that screw while in the process of cleaning the Carburetor and I went to reinstall it and now notice that the hole is larger than the screw thread and it is not threaded. There must be something that it screwed into inside the casing of the carburetor that has dropped out of site. It really has me puzzeled? It does not run correct with the hole being open however if i plug it it seems to run fine.......?
Could have been a vacuum port?  For now i would put a dab of silicone over the hole and let it sit over night to properly dry. At least you can ride.  In the meantime you can research what it passably could be for. Maybe even take a ride out to your local Suzuki dealer and ask one of the mechanics or have them bring up a more detailed blow up of the carburetor.   I will keep looking as well to see what i can find.
    • By Kawiherder
      It starts and runs Ok but after a while the temp gage lights up and the fan fails to start.  Any suggestions on where to start looking would be helpful.  Thanks
      Hello there
    • By Sofaspud
    • By Am2007
      Hi everyone,
      owner manual
      service manual
      engine manual
