On my warrior the rear spring is adjustable. I can't tell from the pick but maybe it's not adjusted up enough. Could be the old spring is bad too. Check adjustment first.
I’ve also seen the previous owners place them in the wrong spot or use the wrong shock all together. You’d be surprised at the amount of stupidity is astounding. If it doesn’t sit level at the frame. There is a problem.
I’ll bite into this a bit further. If someone was going to lower it. Wouldn’t the front match the rear? Why only the rear drop? Is it the reversed rake look they went for? I’ve seen it on trucks. Not quads. That’s asking to replace cases every time you’re in the woods. I can see the full body drop for street racing. I doubt you want to do that.
    • By toe420
    • By Callaway
    • By opnea
    • By Rick Shropshire
