2000 Yamaha 350 Warrior Not Getting Spark
By Topendcol
Col
By Uglyside38
By huntindog
TIA
By Uglyside38
Has anyone had any luck converting an older quad from a 7 wire CDI to the newer (and cheaper) 5 wire CDI?
I have a 1988 Suzuki Quadrunner and I believe the CDI is on it's way out...🤦🏼♂️ A used CDI from 1988 goes for $250-$300 on the bay...and that's when you find them. The Chinese CDIs for the 1990 and up quadrunner are only about $40. I have read a blog from a guy who says it's possible and that 2 of the wires can be omitted if the rectifier is a newer one also. Any experience with this would be greatly appreciated!!!🤙
By Werewolf
Similar Tagged Forum Content
- 0 replies
- 1,447 views
- 0 comments
- 4,269 views
- 3 replies
- 4,280 views
- 2 replies
- 1,618 views
- 1 reply
- 2,346 views
