By BillR94
Thank you for your time
Bill
By wjmedic
right front hub again
By sunn
Has anyone had experience with the installation of the Optional RH Side Panel Close Off Kit as shown as p/n 2207445 which is supposed to help control the heat on the right side on my legs? Right now that panel is wide open with excess heat on my leg.
By Trent Finnessey
