Friend of mine picked up an LT80 that needs some work. The manufacture date is 11/1986
The fuel and vacuum lines for the carb were all disconnected. I picked up a new card and was hoping someone on here has a photo or knows how the lines are hooked up
Thanks in advance
  • Ajmboy changed the title to 1987 Suzuki LT80 Fuel line routing
    • By DaveswMN
      Thanks for any thoughts.
    • By Freddie
      My first quad and I have a problem. I have a Kawasaki Bayou 300 1997. When I start it. It will go on high idle for about ten seconds before it goes down to low idle. It does this even when I don't touch the throttle or the choke.
      Also, when I give it some throttle and let go. It will come back to fast idle for about ten seconds before it comes down to slow idle. Therefore I have to wait for it to slow up before I can shift. The throttle linkage drops right back to the stop on the carb buy the rpms stay up for a while. If you have any ideas what might be wrong please let me know. thank you Fred
    • By CaptJim
      Hello guys, I hope I am not invading your space, but as you can see the current state of my project here it's not but about 50% ATV. I am hoping that some one here can point me to a wiring schematic that I can reference since the "Complete wiring harness" i purchased from Amazon did not include a diagram of any kind.
      The ones that I am finding on line vary greatly but none show the connections for the separate 5 wire connector coming from the motor.
      Can someone tell me where these wires go?
      Thanks in advance for all help!
    • By SashaGraves21
      I know this seems stupid to ask but how do I know which fuel line goes to which intake valve on my 1996 Polaris trail boss 250 2x4. It’s only single cylinder but I found out today the machine had little to no oil or gas and that caused a ton of problems for me to fix now. So how do I get it right?
    • By pjb274181
      Quad can turn very tightly to the left but very wide to the right.  On inspection, when turning right, the pitman arm hits the EPS controller - it doesn't when turning left.  The quad had been rolled (prior owner) and the steering was straightened.  I believe that the pitman arm is now slightly offset.  Can I disconnect the tie-rods from the pitman arm and then remove and reattach the pitman arm in a more centered position, and then reattach and adjust the tie-rods?  Or is the pitman arm not adjustable since there is a grove that it must align with on the EPS?  If not the method I suggest, how would a person fix the issue?  Would the entire steering system need to be taken apart and reassembled?
      Thanks very much!
      Phil.
