Please help. Iv got an 1990 lt80 that will not charge the battery. I can’t seem to find the answer to the problem. Is it the rectifier or the Cdi box or something different all together. I can’t seem to find any rectifiers for it so I’m stumped and I don’t have a manual to read up and find the answer.
  • 6 months later...
Did you ever find an answer to this? To check a rectifier you can check the diodes with a multimeter. Should have .3-.8vdc one way and none the other way. Also, check the stator legs for continuity to eachother and no continuity to ground.
As everyone else has said check those things, also try and locate a service manual. They are miracle workers sometimes. I would check rectifier sign the known good values. They are easy to pull out and check them or leave them in. Also check the battery itself.. I’ve had my fair share of luck with factory dead cells.
    • By LMI
    • By tflack500tbx
      Background,
      Any Ideas?
    • By ButchM
    • By tds7
    • By dkgg5755
