Just foolin around.....
Mounted the cam to the Front fender this morning.....Looks like chit on my Screen.....Maybe I need a new Monitor or I just dont know how to adjust it....What does it look like on your screen???? Grainy????
[ame=http://www.youtube.com/watch?v=PFXhMN8u99c]YouTube - Archos Front Fender Trial[/ame]
Quality looks great to me. Considering it is a camera mounted on a quad and it probably didn't cost $10,000; it's pretty good.
What kind of camera and mount did you use?
If Velcro does the job, might as well use it! I've looked at different helmet cams in the past but never bought one. I had been looking at the ATC 2000. What you have seems to do the job.
    • By jay41198
    • By TomJulio
    • By TomJulio
    • By Olchap
      Thank you,
      Olchap
    • By wjmedic
      Recently rebuilt front end on this Polaris 400. New axles, bearings, seals, control arm bushings, Hilliard clutch thoroughly cleaned and inspected with no damage noted.
      Everything put back to together. Placed bike on jack stands all four wheels off the ground, started in 2 WD switched to AWD both front tires spinning, when AWD turned
      off right front wheel will not disengage from AWD. Checked voltage at connectors both left and right connectors have no voltage with AWD switch off, and both have 12.4V
      when AWD switch is turned on. Repeated turning switch on and off several times with no change in condition. I am thinking this must be something mechanical with the
      Hilliard clutch on the right hub ie. weak spring or stuck rollers on the Hilliard clutch assembly (Is this a logical thought?) any ideas on trouble shooting this before I disassemble the
      right front hub again
