  • Admin changed the title to 1996 Yamaha Kodiak 400 Leaking Fuel New Carb
Float valve not sealing properly in the float seat.  Is it a chinese clone?  Those usually have hard rubber and can cause all kinds of issues.
Try taking the float valve out and polishing the seat with a q-tip in a drill and a touch of carb cleaner and hopefully it'll seal.
Yeah could be a leaking float needle valve, or the float level might be set too high, or there might be a leak between the float needle valve's brass housing/seat and the carby body.
Take the carby apart and pull the float out, then the needle and then the needle's seat. Check the "O" ring or washer that seals between the seat and carby body, then put that in and check the needle's clean and put that in, then fit the float and check it's height adjustment.
About 4 years ago I bought a Chinese made carburetor for a spare just in case I needed it. This last Duck season my 2004 Yamaha Bruin 350 4x4 started running terrible it would not idle it would die so I decided to try the new Chinese carb I had. While I was removing original carburetor I noticed one rubber tube connected to the carb was cracked over half way so I proceeded to remove and install new Chinese carb. After the installation of the Chinese carb I started smelling gas so I found gas leaking from new carburetor so I figured I would install the original carburetor because I replaced cracked rubber hose. After installing it ran great it idled perfect.
then I started smelling gas again it was leaking from the overflow tube at bottom of carburetor. So I ordered a new oem carburetor from Partzilla.
received new oem carb installed it runs great and no gas leak
I had the same issue I I disconnected the carburetor except for the throttle cable flipped it upside down remove the bowl used carburetor cleaner in copper wire cleaned all the Jets in the overflow tube put it all back together and it ran great and stoped leaking gas !
4 hours ago, BUKNDUK said:
I learned my lesson I will never buy a Chinese Carburetor again oem is the only way to go
Governor springs are even worse.  Generators need the proper rpm to operate.  Mix and match governor parts are a disaster.
    • By WeeBee
    • By hurnyak
      What is the best way to remove the carb on a 2000 quadmaster 500? Does the gas tank need to come off first?
    • By LCP92
    • By dkgg5755
    • By Louznmemind
      (Question is at the end if you want to skip my blabbering) I got this unbelievably well taken care of Grizzly 350 in for a carb clean, it belongs to an elderly couple that bought it brand new in '07. Apparently whoever has been doing their oil changes for them never checked the air filter..
      Obviously it got debris in the carb, it would still run but only idle with slight choke. I've taken it apart and cleaned it, have new o rings, gaskets, etc. As far as the mixture screw is concerned, I'm assuming I obviously need to remove the plug. I'm mainly a lawn equipment guy, I've worked on slide carbs in the past but never an unmolested one with the plug still intact. I hate to mess with it as the carb had very little debris but I'm sure the o ring needs to be replaced at minimum. Finally, the question: what's the best way of removing the plug? I DO NOT want to mess up this carb..
