Hi all, new here and trying to figure out an issue with a Bayou 220 I just got. It sounds (to my novice ears) like it ticks more than other engines I’ve heard.  I also hear it occasionally backfire (briefly) and the engine gets very hot (I’ve never run it enough to shut down).
I’m thinking it needs a valve clearance adjustment but I’m wondering if any other experienced Bayou owners or anyone else has any ideas before I start tearing into something I don’t need to?  Thanks everyone!
Edited by Khanh845
  • Khanh845 changed the title to 1995 Kawasaki Bayou 220 ticking noise
If you haven't done this yet,  I would change the oil, check the air filter, and check/replace the spark plug. Any difference in running when you apply the choke?
Thanks for this. I can definitely do that. I don’t know when it was last changed since I just picked it up but can I ask why or how that might make the ticking sound?
well I adjusted the valves four times. I tried setting it at the low and high end of the range in the service manual and it still ticks. I wonder if there’s just something wrong with he valves themselves or something more.
    • By Joeguy
    • By oztrax
      MAX 4 6X6 2008
    • By Dsluder
    • By Jdeaton011989
    • By marlon smith
