Similar Topics
By hporter1208
Okay, so I have a 2002 Rubicon 500…bought it last year and it sat for several months until I put a new rear axle in, FINALLY got that done and was super excited to finally have my wheeler going, just to notice a strong gas odor. Popped the seat off and sure enough, pouring gas from the carb overflow. Fast forward a few more weeks and get the new carb and get it in, no leak! Yay. Except now I have no spark. 😒 I’ve tried another plug and checked and am getting no power to the coil pack. I’ve read and read and mostly what I’ve found is ECU, which is fine…but I like to exhaust all avenues before buying the more expensive parts just because I don’t wanna spend the money and it have ended up being something simple that I overlooked because I was trying to rush. 😂 I don’t know if it’s relevant, but I read on another post that someone had similar issues with theirs and it was the sensor on the side of the carb, just a thought since this literally happened after I put the new carb on. It also displays “- -“ on the display screen where it should show the gear position.
By Shadow1
Now i have that korean atv he making a noisy sound on the rotor side so i checked it and i have the starter driven gear moving in its place there is like a 10 mm space that the gear can go back and forward and a little space between the gear and the crank i think theres a beering missing!!
By BuddyLee
Just started to bog in gear. Chineses carb. Taken apart and cleaned. Starts good, runs good, throttles good sitting there but as soon as try to go it will bog. Plug is black so I cleaned and adjusted needle downwards. Kinda lost at this point…ideas? Thanks in advance.
By Ulfthednar
Besides a winch that is.
Im not new to wandering around in the woods but new to doing it on an atv.
Ive already equipped an axe, tree strap and clevis and am looking for a shovel.
whats been your most valuable piece of gear outside of a strap and winch?
By e.p.
Hi all;
New to the site. I have a 2004 Yamaha Kodiak 450 YFM45FAR that I'm having issues with the gear indicator lights. I'm having intermittent park and neutral lights and when they are not lit the starter will not work. It will start by the pull cord . Anybody else have this issue. Any help is greatly appreciated.
Thanks.
Similar Tagged Content
- 6 replies
- 2,928 views
- 1 reply
- 1,421 views
- 5 replies
- 2,711 views
- 50 replies
- 10,286 views
- 17 replies
- 8,136 views
Gallery Images
