Anybody Here Know If It Would Help To Put Spacers Behind The Clutch Springs On A Sport Quad??, It Shuld Grab Harder So I Dont See Anything Bad Coming Out Of It!!
No,,,,I dont think so....Just buy some Stiffer Springs and be done....While you are in there.....If your lookin to save some money.....Pull the Disks our of the Basket and Rough them up a Bit.....That will help you out some....Sounds to me like your due for new stuff in there or on the VERGE:huh:
Don't think that would be a good idea, your clutch might not want to disengage all the way as there will be slightly less spring travel available.
I could allways adjust the prussure plate so that the clutch fully disengages. they have quiteabit of adjustment space.
    • By logray
    • By mikeexplorer
    • By quadnut20
    • By sunn
      The clutch engagement on my 2021 cforce 400s was approx 2700 RPM, very abrupt/not smooth.   I obtained a "kit" from RNG consisting of a blue painted spring (spring force unknown) with 12 gram weights, as measured on my postal scale.  Installation was easy; 18 mm and 30 mm (not 32 mm as seen on other writings) impact sockets for clutch housing removal.  The resultant clutch engagement was still up to approx 2500 and very abupt/not smooth.
      The RNG spring was slightly longer than the stock spring, but felt slightly easier at initial downward force but had more resistance than stock as I continued to push down.  RNG would not tell me what the spring force was.
      I am really struggling to get any answers on the best combination of spring / weights to achieve a smooth engagement of maybe 1800 RPM.  Note; idle RPM is approx. 1600.
      I have searched all the forums and cannot find good information, and RNG appears to be not willing to share information.  What gives here?  Anyone with experience to share?
    • By Coyote251
