My Moto4 project
tin
Sound like the engine is not locked up I would squirt some oil down in the cylinder to make sure rings are well lubricated before I turn it over much. I would pull the drain plug not completely at first just to see if any water comes out then pull it all the way out and let all the oil drain out look at it to see if its milky looking, and change the oil. From the photo it appears the master cylinder needs replacing you can take it all apart clean it and try soaking the rubber parts in brake fluid but in my experience it won't come back. As far as electrical look for corrosion on connectors and fuse box and check the ground. Hope this helps a little, 25 years is a long time to sit out in the weather.
The photo is just the thumb lever full of ants.... I'm not that worried about that part at this stage. I cleaned the ants out and sprayed the inside of the lever with plenty of WD40, so hopefully by the time I get to look at it next it'll have come free.
They did have it covered with a tarp for most of the 25 years, so it's not too bad.
I just rehabbed a 88 MOTO 4 200 that I picked up for $300 off of Market Place.  I got a fully operational machine on the trails for under $600.  Parts are cheap and plentiful on Amazon.
All I needed was a coil, a carb (the price of a carb is not much more than a rebuild kit, saving a lot of tedious work), a new petcock (the handle was broke off) brake pads and front brake cables).
Oh yeah and redneck engineer the the air box as the door and cage were gone and I was unable to source them for a reasonable price.
Good luck on your project and have fun.
Hi Tin, that doesn't sound foolish at all to me! That's what my grandson and I do for fun, we've been restoring a 91 Moto 4 250 that we got as a basket case a while back. A least yours is all together 😂. But most parts are available with a little scrounging on Amazon or Ebay, and there are quite a few in the salvage yards as well (we've had really good luck with Power Sports Nation), and you can usually get an answer to any problem you run into on the forums here. Look in to downloading a manual for it here, that's pretty much a gotta have.
Good luck with it
I'm not exactly young... I'm older than the bike 🤣
The plan for it is mostly to do with weed control, fence maintenance and eventually stock movement. We may still buy a newer one aswell, but I want to get this one going anyway.
Unfortunately I've had no chance to look at it any further because it's been so wet here lately. Can't even drive down the driveway at the place it's at, and we had to make a rush trip to a different property the other day to feed chickens before the road got cut off from flooding.
I'm a mechanic and I always find there's a bit of a moral dilemma too in fixing thing up to sell for a profit..  Just how gooder job do you do, and how honest are you going to be when you sell it.
I decided early in my career not to ever do that, buy and sell, after seeing mates do it.. to their discredit.
Also, over here, the tax rules say that anything you do, even a hobby, is taxable if it's "ongoing", or "regular".
I value my reputation for honesty, given I operate in a small community, and my integrity, too much to be seen as dishonest in any way... even to  the IRD.  Even though people would consider it ok to deceivethe IRD, it would still reflect on the worth of my word..
The crux of professional behavior is giving people confidence and trust in your methods and procedures. Anything that detracts from your trustworthiness undermines that.
Now, my son is a qualified mechanic, and he started doing bikes up, against my advice, and after having the dilemma explained to him, and he found out real quick, despite his resolve to do it honestly and fairly, that it was really hard to make money without cutting corners.
Now he just fixes them for fun and to get bikes back on the road or track.. That works. He does a good job then, and breaks even, and everyone is happy.
Hey Tin,
Sounds like a good project. I have a 1988 200, which sufffered an engine fire. They are easy to work on, but you may have to get creative for some of the parts which are no longer available. Im new to the site as well but fell free to PM me if you have any questions. I will try and uplaod a pdf shop manual as I have one.
Take care
moto 4 manual.pdf
On 9/23/2022 at 3:51 PM, Mech said:
Ha.. Yes mate, that's exactly it. Good to hear.
And aircraft eh ? Were you an engine guy, or airframe ?  Those old piston engines are something aren't they..  Beautiful..
Yeah I've been at it for going on 40 years, back and forth between fixing 'em and flying 'em. So I've done lots of airframe work, as well as most types of engines from the old radial piston's to turbofans. And yes, the old piston radials are amazing, a bit like working on a giant watch! 😄
Well it's been a few weeks... It's been flooding on and off here since I last posted, so didn't get much time for side projects.
Weekend before last I took a trailer out to where the bike was sitting, loaded it up, and brought it to town to work on in my garage. Much nicer than under a tree at someone else's house with only the tools I thought to grab and take with me.
Since getting it home, I've spent some time trying to check the wiring... Discovered what looks like some DIY wiring repairs. Lots of crimp on generic single wire connectors.... Including a batch that are jammed into one of the factory connectors. Also found theres a busted wire on the key switch - the switch is fine, but one wire doesn't conduct. It's on the kill side not the run side, so I'm not that worried just yet.
And tonight I removed the stuck screws on the rope starter cover and got that off. Lots of dirt inside, which I've scraped out. But the spring seems to have completely let go. Not sure how or even if that piece comes apart. Leaving it off for now, but definitely want to try and repair it for the inevitable flat battery while stopped at the far side of the farm.
Planning to hook up a random 12v battery next and check through the wiring around the neutral and reverse switches and indicators. I feel like having those known working is going to be a big help in testing the starter circuit.
Update on my progress...
I had a play with the rope rewinder unit the other night. Still not sure how it comes apart, and is not mentioned in the service manual (not in the one posted above anyway). The nut on the centre spins freely, so I can't undo that. There's some sort of spring clip thing under the plastic that I pulled out, but that didn't release anything (it was already loose - not even sure what it's for). If anyone has any tips or guidance or anything for this part....
Next up was some fiddling with the electrical side. I hooked a dead (sitting at 5V out of 12) old lead acid battery up just to try and chase out voltages on the indicator lights and such. Quickly discovered the voltage was dropping off fast, even with everything turned off. Managed to trace that to the voltage regulator. That has been my mystery resistance the whole time... Unplugged it, and I now have an open circuit with everything switched off, and if press the engine start button, I get a resistance again (the coil in the relay, I assume).
With limited access to any 12V batteries, I grabbed one of my 3S RC packs... just to see if the neutral/reverse indicators would light. Nope. For shots and goggles, I pressed the start button very briefly... And we have starter... Or at least the relay clicks. I didn't want to kill the battery so it was an extremely short press.
And right now I've just solved the mystery of the indicator lights... They're both blown bulbs. Doh! This whole time I've assumed it's something worse, but it's just bulbs. Dang it. Oh, well... I already had down to replace those with LEDs at some stage anyway.
Ha good onya mate.
If those pull starts are like a suzuki the nut in the middle that turns, will be seized onto a shaft that comes up through everything that it all spins on. That shaft is meant to be attached to the tin cover. I'd probably try splitting the nut open with a chisel and anvil till it turned or split right off, and then brazing the shaft back onto the cover.
I was thinking it was probably supposed to be attached to the housing. It looks basically the same as that diagram. I'll probably cut a slot with the Dremel and see if a screwdriver can hold it enough to unscrew it, then cut it right off if it doesn't. I want to at least get the cover back on for safety if I can't fix it. Long term, if the quad runs OK, I'll buy a new housing anyway because this one has a hole in the top where dirt gets in.
    • By NZrider
    • By jatho
    • By mkibbe
    • By jatho
