2007 cat 700 efi fan issues
By Mikey509
By LMI
By colin james
View File 2017-2019 sportsman 450/570 with eps factory service manual
This is the factory service manual for the 2017-2019 factory service manual for the sportsman 450/570 with electronic power steering
Submitter colin james Submitted 09/06/2018 Category Polaris ATV
By HeWasRidinDirty
I rebuilt the carb on said machine. When I hook up the auxiliary gas tank it runs fine and everything is cool. When I put the fuel tank on and hooked up the lines, it completely flooded the cylinder and even about an inch of fuel in the air box. I'm pretty sure that it comes from the little hose on the petcock and hooks to the top of the carb. WTH is that even for? I mean the thing runs fine on the auxiliary tank, so idk And on the petcock when it's in the "on" position, I get no fuel. The petcock from the bike I took it apart and checked out how it operates. The sharpie marks indicate how it really works. Now the other petcock w/o the sharpie marks is an old one that was leaking that I removed from a Polaris quad. It's exactly the same thing, except the small hose and nipple have been removed. I'm so confused, LOL
By jeffrocdx
