Alright so I did some poor planning and put some oversized tires on my ATV. I ended up getting a lift which helped the rubbing at the top but in the rear specifically the tires hit the foot rest/skid plate. I removed those and will figure something out but for now I need to know if/how you all moved the plastics.
For the rears, I would need the plastic to move toward the front to open more space and in the front move plastic back.
photo attached if you have ideas.
Perhaps you could heat and bend the bodywork, or make some brackets which keep it away from the tyres.. or.. last resort, cut the bodywork away so it doesn't touch.
I’d prefer not to cut it since it sits up fairly high at the touch point. I could see bending or moving the attached brackets forward so it pulls it away further from the tire.
We just had some snow fall in michigan so I need to do something soon since I’ll be using this to plow.
Very nice ride I would definitely not cut it you should be able to fabricate a bracket from aluminum so it wouldn't rust and sister it to your original bracket  under the wheel well out of sight.
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
    • By quadnut20
      Looking at replacing tires on my 2003 Foreman and was seeing what everyone is recommending fore it ?? Its mostly a plow machine but in the summer the  kids take it out !!
    • By kingkw
      I have a Harbor Freight tire changer. I could not get the tires off the rim.
