By T37Mark
By joezee13
By davefrombc
It would be helpful at times to have a button where we could cont the Admin. to make some changes to our posts.
By pastorjeep
Ok guys, I am a glutton for punishment! I picked up this 01 2wd Rancher because the plastics looked good on the marketplace. It has been sitting in the guys back yard for 10 years. The original engine blew and they swapped in an electric shift 4x4 engine. 😒The engine is locked up and was full of water. The wiring is hacked where they tried to get it to run and the rear end needs new swingarm bearings where they left it laying on the ground in the woods for 10 years. Has anyone here ever did the engine swap? First thing is to straighten out the wiring and get the engine free to see if I can get it to crank over. I have swingarm bearings ordered and a new ignition switch. So hopefully I can at least roll it around soon. 🤣
By cruteg8
hello i am a new member to Quad Crazy i own a 2000 warrior 350 and just bought a Kawasaki Lakota sport 300 with a blown top end
