2006 Polaris Sportsman 450 No 4x4 operation?
By HoldenBoy
By McG75
By McG75
By Louznmemind
Howdy y'all, I'm trying to fix a neighbors 2015 Brute Force 300. Came in with hard to start and won't idle except on choke issue. I pulled the carb and found the pilot jet as well as the emulsion tube partially clogged. Cleaned up everything, put it back together, still having issues... It will start right up on choke and will also start off choke if you give it just a touch of throttle but it absolutely will not idle unless it's choked just a touch. Also, excuse my ignorance but I'm assuming the "dial" thingy attached to the carb that turns in and out is for setting idle??
By Kawiherder
It starts and runs Ok but after a while the temp gage lights up and the fan fails to start. Any suggestions on where to start looking would be helpful. Thanks
