2006 Kodiak 450 4X4 overheating
BeauHymel
New here, I am having trouble with my bike overheating. The temp light is working but the fan will not run. The fan will only run
with the ignition in the off position (Key removed).   Not sure how this is possible. Also having electrical problems and it will ruin a battery (if not
disconnected) about every 3 months. Any help/ideas would be greatly apricated. Thanks in advance
Edited by BeauHymel
If you go up the top of the page, click on "more", choose service manuals, and then in the new page that opens, on the right and down a bit choose yamaha, you'll find a manual..
Have a read.. It doesn't really sound like the sensor to me.. not with it only going with the key off.. If you find the right book for your bike and let me know which manual it is I'll have a look at the wiring diagram and see if I can spot anything.
If you bought that quad used and this has been happening almost right off, it might be someone has messed up the wiring to the fan. It seems to me from your description that possibly the hot wire is going directly to the fan  and the ground is switched by the relay.  Fan stays off until the sensor calls for it to  run at temperature  but the ground is switched off by the relay. When the key  is turned off the relay switches to  normal off position and in doing so  actually grounds the fan  so it'll run.. As  Mech says , there should be a wiring diagram in  a service manual  covering your machine in the download sectio n to help  you trace down the gremlin..
Manuals are available to download elsewhere.. Some you can read and search one page at a time online which is handy if you have limited or slow data/internet. Handy too to verify it's really for your model before you download..  But keep posting.. and you'll get one here.
Your bike is water cooled right ? And does it have belt drive, or a solid trans with five speeds, and if belt, how many forwards speeds does it have ?
I'll see if I can find the right manual and have a look.
Not sure if yours is wired like this, but the few water cooled units I have worked on have a thermo switch on the radiator that turns the fan on and off as needed, if you bypass this switch the fan will only run with the key in the off position, that's my reasoning for thinking the thermo switch is bad. Now if yours has a relay like Dave suggested that may be different.
I've looked at a couple and they both show the key switch having two power in and two power out, both  working in parallel. One power out feeds the fan only, and the other power out feeds all the rest.
I'd guess the switch needs pulling to bits.. one of the slides playing up.. I'd say. But check it with a gauge before you pull it off and to bits.
Thanks, I check in a few days, the bike is at the deer camp. To answer other questions.
The bike was purchased used, but 10 years ago. Started having issues 2 yrs ago with battery going
bad after only 3 months, killed 3 different batteries. Checked for parasitic amp draw and showed none.
Changed key switch and then RECTIFIER & REGULATOR with no luck. Installed a battery disconnect and
had no issues with battery since. Don't know if the fan coming on was killing batteries or not. It was recently
I noticed the fan coming on with key off. I need to figure out how the fan is getting power and ground with
key off and not with key in the run/on position. Sorry for long post just giving some history.
Also the bike is a 2006 Yamaha Kodiak 450 belt drive IRS YFM45FAV with no modifications
Thanks again.
I think Mech answered the power source to the fan  with key off.. There are 2  power source in and out on the key switch,  so  likely the second circuit is the one that powers the fan in  key off .. I would suspect the fan sensor is faulty since It would appear to me the second power source on the key switch is to provide constant power to that sensor to power the fan when the motor is still  hot  after shut down.  When the motor  is below fan  triggering temperature it should remain off no matter which circuit is powering it .  Check the output of the fan sensor with the motor  cold there should be none if the fan is powered directly through it , and if  there is a relay the fan sensor triggers,  check that relay for it  being failed on ( points fused closed) delivering power to the fan constantly.
