2008 300 cc MountainView Roughneck no spark (Chinese ATV)
By
PKR
in Other ATV Brands Forum
Go to solution
Solved by PKR,
By logray
By cruteg8
Does anyone know the orientation of the bell crank for scrambler 400 2x4 it was not hooked up when I bought quad the way i put it high goes into reverse and vise versa I flipped it 180 but that put the shift rod at big angle and it just kinda grinds into gears so dnt think that is right either pretty sure it has to be the exact orientation and the rod adjusted accordingly but I cant seem to find it anyone knows please help
By HoldenBoy
By crankin
By cruteg8
