I use ArmorAll or similar vinyl preservative on the plastics, and keep the engine polished with Colonial Brassy or Wizards metal polish, I haven't had any problems. Just don't let it stay on there very long some mud can be very acidic.
You mean I should let the mud stay long? Or the chemicals?
I will try the ArmorAll  preservative on the plastics, and keep the Wizards metal polish ro for the other parts.
How should I keep the harness and connector protected from mud/water?
I meant not let the mud stay on there very long, vinyl protectant, I spray it let it alone for about an hr and wipe the excess off, it really just replaces the moisture lost by sun exposure and age, the metal I just keep it polished and smooth, wiring harness I don't worry about that too much, but I don't do a lot of heavy mud riding, where you need a snorkel to keep the engine running, I do have a snorkel but I try to be semi respectful of the machine.
I use Turtle Wax Hybrid Solutions Ceramic Spray on my plastics. Don't spray on your seat or hand grips, it makes them slippery.
On the engine I just get the majority of the mud off then use an automotive engine de-greaser like Gunk or Oil Eater.
As far as the harness just keep an eye out for any breaks and fix them immediately. If you can, wrap your harness in split loom wrap and make sure it's taped up real good. Also use some dielectric grease in your connectors, it's fairly inexpensive and helps prevent corrosion by keeping moisture out of the plugs.
Fill electrical connectors up with vaseline or white petroleum jelly(same things) and it will waterproof them. I used to put it all over my HT leads and cap too and could go through water up to the handlebars on my old two wheelers.
Is there any spray you can used for the connectors?
Nothing as good as vaseline..  WD40 maybe. Or some spray on grease..
I actually use white petroleum jelly which is a slightly heavier grade of vaseline, and there is amber petroleum jelly also thick. Both can be got in tubs from an engineering supply shop I'd think. It's cheap and good for holding things in place when you are assembling things and waterproofing and several uses.
Edited by Mech
  • 5 months later...
Believe it or not, I've had good luck with Pledge. Spray on and wipe in a circular motion, and do this for the whole surface. It makes the surface very slippery in general and things tend to slip off of the surface. I think this helps to prevent scratches for the same reason.
Dielectric greases work the best on connectors.  Vaseline isn't good for plastic connectors, over time they make the plastic brittle.
    • By WeeBee
    • By mikeexplorer
      16th annual event to raise money for cancer research, For $25 you get a 64 mile ride and a chicken BBQ dinner after the ride. Can't beat it.
    • By mikeexplorer
    • By cruteg8
      I was thinking about trying to repair some cracks in the plastics of a Lakota Sport i just purchased has anyone ever tried (U.S. Chemical & Plastics USC GarageTM Flexible Glaze USC-77704 it) https://www.ebay.com/itm/364866165725. i was thinking jb weld for plastic then using this as a bondo that can be sanded smooth
