Pulse pump on 2008 300 cc Midwest Roughneck
By
PKR
in Other ATV Brands Forum
Go to solution
Solved by PKR,
By LCP92
By DexKing
By Kurt Reiser
My quad will not run with the airbox hooked up Will not go past quarter throttle as soon as you unhook the tube at the back of the carburetor it runs great does anybody have any ideas what it could be I have a bad fuel pump one on the way can that cause the quad to run like that
By kawasig
By Gwbarm
