Moto 4 sub trans questions
By Cj Winds
By HoldenBoy
Hi all,
By jeffrocdx
By cruteg8
Does anyone know forsure if u can swap out the Crank Case on a 2001 kawasaki Lakota 300 sport with a kawasaki Bayou 300 Im seeing yes and no all over some say the mounting position is different so you can't swap the cases but everyother inernal engine part you can swap then im seeing no problem bolts right on can someone plz clarify who knows forsure
By Jason39
I’m having a issue with my choke when its on it runs fine when I cut the choke off the atv cuts off went to take the carburetor off and saw the choke plunger broke at the nut to screw it in could this be my issue? Do I just need to buy a plunger kit and put it on? I took the carburetor off and cleaned both jets anyway just to make sure and it’s still having issues staying on
