KLF300 1994 spark plug cap resistance
Go to solution Solved by Params_sweden,
Hi! I'm new to the forums :) I'm working on my klf300 that isn't starting anymore. I accidentally ripped apart the spark plug cap, and I'm curious to know the resistance of the original part, it's not mentioned in the manuals. If anyone with a KLF300 could measure their OEM or known working replacement spark plug cap I would be very happy :) NGK for example has spark caps with resistances 0, 5, 10, 15 ohms so it seems to be something that I would like to match as close as possible with the original part.
Thanks,
Pär, Sweden
Don't have a Kawasaki, but for my yamaha 400 the manual states it should be 10000 OHMs, the after market coil I just received only had 7 , and the one I ordered before that only had 3. If you need to replace it go OEM to get the correct specs.
The test in the book says to test the coil with the cap off the lead, and it should be between 10-16 Kohms..  I suspect the cap doesn't have a resistor built into it.
Use a small split pit shoved up the lead and clipped onto the spark plug and try running it, if it runs ok and doesn't make massive interference to a nearby radio then it will probably have a resistor lead on the coil and it will be ok with a zero resistance cap.
Thanks for your input, I'll give the radio test a try in a moment! Like almost every Bayou owner mine has ignition issues, in my case weak spark or no spark, so I'm trying to rule out everything one step at a time. I ordered a NGK spark plug cap VD05F with 5kOhms resistance, it was like 30% of the OEM part price :)
did it solve you issue?
Thats great you got it fixed, did you end up going with an OEM coil or aftermarket, some of the other guys with the same issue might be interested in which coil you ended up getting.
    • By RGS
    • By oxidized_black
    • By Kawasakibayounospark
