KLF300 1994 spark plug cap resistance
Go to solution Solved by Params_sweden,
Hi! I'm new to the forums :) I'm working on my klf300 that isn't starting anymore. I accidentally ripped apart the spark plug cap, and I'm curious to know the resistance of the original part, it's not mentioned in the manuals. If anyone with a KLF300 could measure their OEM or known working replacement spark plug cap I would be very happy :) NGK for example has spark caps with resistances 0, 5, 10, 15 ohms so it seems to be something that I would like to match as close as possible with the original part.
Thanks,
Pär, Sweden
The test in the book says to test the coil with the cap off the lead, and it should be between 10-16 Kohms..  I suspect the cap doesn't have a resistor built into it.
Use a small split pit shoved up the lead and clipped onto the spark plug and try running it, if it runs ok and doesn't make massive interference to a nearby radio then it will probably have a resistor lead on the coil and it will be ok with a zero resistance cap.
Thanks for your input, I'll give the radio test a try in a moment! Like almost every Bayou owner mine has ignition issues, in my case weak spark or no spark, so I'm trying to rule out everything one step at a time. I ordered a NGK spark plug cap VD05F with 5kOhms resistance, it was like 30% of the OEM part price :)
did it solve you issue?
@Gwbarm Yeah feels good! I bought an aftermarket China part from a Swedish seller, unfortunately it's a no-name product, when I got it it didn't match the image on the sellers site. Here's a link https://www.merafritid.se/tändspole-kawasaki . It came without spark plug cap, the "ignition wire" has a black outer rubber and a white center.
  • Thanks 1
    • By Flash_fella
    • By pitts
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
    • By oxidized_black
    • By bob2007
