KLF300 Bayou 1994 EU with weak or no spark issues
Go to solution Solved by Mech,
And she started right away :D Thanks for your invaluable help every single one of you 🙏 I learned a lot in the process, I'm way more confident when it comes to simple troubleshooting of these things now. Most important lesson could probably be found in that the "old" coil seemed to work judging from the resistance tests, but when tested in isolation it didn't give a spark.
Special thanks for your insights @Mech, really appreciate knowing more about the theory behind it.
I'll send a video of her running tomorrow for a nice wrap up of this thread. Will also mark one of the posts describing how to bench test the ignition coil as the solution for clarity.
/Pär
    • By Spritee1
      not sure where to look next
    • By cavry
      Wiring shows White and Brown to solenoid blades. Then a black wire from starter circuit relay to solenoid. I am confused,  where is that black wire supposed to connect?
      Thanks for any help
      Cavry
      Anyone here ever have any issues with the law for riding on public land? Im in upstate NY and they seem to ruin everything so Im over cautious.
    • By Mhatayas
    • By John Sinclair
