The 570 would definitely have more power, it depends on what type of riding you are doing, all of mine are 400s and for what I use them for I do not need anything more powerful. Not really sure what you are looking at, do a side by side spec comparison, that might help you decide.
A quick look through the specs show they are almost identical except for the displacement, and the engine design.
The 450 is a single over head cam and the 570 is a double overhead cam.. The 450 is almost certain to have a steeper power curve with more of it's power in a narrow range, and the 570 will have a wider flatter power band. If it was a two wheeler the difference on the road would be that the 570 could hold high revs comfortably for longer, and seem slightly less sporty to ride. The 450 would wind out into it's power band quickly, with the sensation of more power, but then make you feel like you wanted to change up a gear more often..
  • 4 months later...
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
    • By blasirl
      As some of you know, I inherited a 2003 Honda Rancher ES TRX350FE and have spent some time cleaning, repairing, and performing maintenance on it.   I have yet to replace the broken breather tubes, but will get to that once I find a place that sells the tube in bulk.  I am waiting on a battery so I do not know the mileage or hours at the moment, but I know it runs well and starts right up.  It does need new tires though.
      So anyways I am trying to value it for insurance.  Any suggestions would be appreciated.  Here are a few pictures .
    • By noticon75
      I'm going to put a winch on my Bombardier Quest 650.  I was going to just go with the Harbor Freight 2500 winch. But I am now considering the 3500.  My concern is the 2500 has only 2 mounting holes? Doesn't seem sufficient. I like the price and it has the wireless remote and the circuit breaker has a cover for it.  The 3500 has handlebar winch control which i think would be better for snowplow so...
    • By JDAlbert
      I have several quads and will soon need to replace tires.  I typically like to have a complete set mounted and ready to swap out for different kinds of riding but haven't done that yet.  What do you recommend and where have you purchased them?
      2020 Polaris Sportsman
      2013 John Deere Gator
      2010 Polaris
