My 1992 Suzuki king quad won’t take gas on throttle.
By DPDISXR4Ti
Thanks...
By Dsluder
By DonB
Had fire start in muffler due to failing fuel pump &/or fuel pressure regulator. Must I spend the $750+ for a new assembly from Arctic Cat?!? Here's what I've tried so far.
Replaced fuel pump & regulator - both from Quantum. PSI is 60 rather than the 42 the dealer advises it should be, so problem persists. I've now twice replaced the Quantum regulator & discussed w/ Quantum. They advise that they don't have an alternative regulator that would bring PSI down to 42. I've tried several in-line, adjustable pressure regulators but they either didn't work or I couldn't get a constant pressure from them. FYI, I've only tried the adjustable regulators for Fuel Injected engines however, it seems that they require vacuum to function properly. When I can temporarily get the PSI right, everything works great. Anyone else ever dealt with this problem, and, if so how did you fix it? Perhaps I should adapt the fuel system to include a gas tank return line?
Any insights are greatly appreciated, Don
By Gwbarm
I generally use Non Ethynol fuel in all my small engines. I just got back from the gas station and that fuel has really increased in price since last year, I will continue to use it, even though its north of 1.00 a gallon more. That seems minor compared to cleaning and repairing carbs every year.
I was just curious as to what others are doing in regard to gas in their quads, i know a lot of the newer ones are fuel injected which shouldnt pose a problem, but i have had lots of problems with rust and jell forming in carbs when using ethynol fuel.
