have a raptor 660 that is doing something a little weird. If i just go along slow it is fine but once I put some pep in it the thing seems to skip every 4 seconds. At first I thought the chain was slipping but I can not see any wear or visually see it slipping. When it does it there is a loud clicking/clanking going on. The weird thing about it is that it does get up and go and will accelarate even while doing this. Any suggestions?
It seems to be. I by far not a mechanic but I am mechanically inclined. I can go and shift through all the gears and pick up some major speed. It seems to do it in every gear. I am pretty sure it is in gear fully but do not know the correct way to verify besides knowing it has pep and goes with lots of torque.
Thats what I thought so I loosened it up. I do know I have an issue with the rear end because the axle has about 1/4 to 1/2 inches of play in the housing. Another hint that might help is sometime when I stall it out (not that I would ever do that on purpose hahaahha) when the engine stops I hear something like a hammer slam the engine.
ok that might explain the kicking when stalling. But when I am giving it some gas and really putting the pedal to the metal the slipping/slapping sound must be a major issue. You think needing a carrier bearing could cause this?
I dont know why I am even telling the truth about what the problem was because it was so obvious and I didn't think to check it. After beating the hell out of it on the track i found that my front sprocket was worn down. I knew it sounded like the chain slipping. Thanks for everyones input.
    • By Coyote251
    • By Frank Angerano
