I have to pull my 500R apart again and get the crank balanced like I should have done before I even put the new crank in. I was so discouraged by the thought of not having anything to ride, I was forced to buy an LT R450. I like it really well, but I really can't wait the have the big 2-stroke back. The 450 is alot easier to ride though, the 500R is kind of like wrestling a bear in comparison
I agree man, there is nothing like a two stroke but you can really get comfortable with the lt. I rode two stroke dirt bikes forever but I really enjoy my YZ and not sure if I will ever go back
What part of WA are you from? I spent my high school years in Olympia.
I'm from Bonney Lake, it is about 15 miles east of Tacoma. Don't get me wrong, I like the LT, it is a nice change of pace from the beast. It handles better, it's WAY easier to start, and the power is more smooth and manageable. But is a bit too wide and low for some of the trails I like to ride, and I just miss the brutal power of my 500R.
    • By cruteg8
    • By sunn
      Any ideas?
    • By middlebrookgt
    • By baller74
      Hi here's the other half of the awesome deal on a quad!
      grumbles when I went to look at this quad the seat was off and the headlight was laying aside the tank. first things I noticed  was the wiring or wires that were cut to the cdi box and the ignition switch also the seat was  off and the fuse off the battery was removed  next was the jumper  cables hooked up directly to the 110v house plug and the smell of burnt plastic and wire permitted the area. the guy selling it wasin a pinch and eeded quick cash so I overlooked my gut instinct and did a quick tally of cost and parts if I had tobuy the whole  electrical system  essentials to make it run again and slowly let the numbers 50 fly out and shut up. the foot crank was stripping bolt snapped  but I turned it over  good compression . this quad was clean as a whistle like brandnew  andthe harness so far is in excellent shape. I stopped at a friend's house and found a kymko cdi since box was actually the maker of this engine. fo free and began my next days adventures dreaming that the wind would be in my face and the cops at my back way behind me hauling as* round town In a couple hours I mean he said it ran just fine the day before ....
      well it's 715  this evening and I'm still trying to find a factory service manual that is free I can download at least the electrical schematis and conponant pinouts with wire color  and a troubleshoot guide with component testing procedures as there more than six wires for the cdi the leftovers are green green with yellow   babyblue and brown with yellow  no eof these are hooked up and she's a dead horse hoping someone could walk me threw them and there correct designation not just spliced I to a hit etc. the wires I hooked to the cdu are white pickup pin 1, blackwhite the pin 2, blackgreen ground pin 3  4 empty  2 plug  slot 1 empty slot 2 brownyellow power. now no been arguing with crapgpt all day sYs the 2 plug 6 wire ac cdi is the oem match for this one. now there was t a cdi when I bought it was "lost" probly along with the "KEY" but the cdi I pulled up shaws a 2 wire boobs 2pluh 6 pin cdi need to know if I can make her go with this cdi I looked at the wiring to that one And shows the stator hot and cold go to those extras  not sure but I am leaning towRd there's N internal voltage regulator built into that cdi box. anyone have the skinny on this I have  a voltage regulator 5 wire from another bike new bit has a pink wire when I put jumpers from my jeep to the battery and fused the hot side up  and tied the red and brown side on it switch no get nada but have voltage from battery to start solenoid  to the cdi hot pin the main harness connectors the headlights the green with yellow and  all the red wires read that brown with yellow is an accessory wire 12v switched used for engine control restrictions  but won't run without constant 12v if this is true I want it bypassed I. 205 pounds and little 200 is gonna struggle enough hauling me don't need any extra help there and infact if anyone can give me a few parts number to buy for some extra preformace and horsepower. I'm on a beer budget after my superchargered wrangler build so pheniox racing gurus and backwood tweeker brothers your input will be invaluable but you would add what you know. alright guy let er ripp I'm all ears.
    • By Atomusthenes
