  • Admin changed the title to 1987 Suzuki Lt300e knocking when down shifting
    • By HoldenBoy
    • By Atomusthenes
    • By PupATV
      -PupATV
    • By jannonballs
      2001 Yamaha Kodiak. Rebuilt and cleaned carb after sitting for 10 years. Got her runnin but now this clunking noise is happening and sometimes the engine stalls hard like the tranny or clutch abruptly stops the engine. This was not happening 10 years ago. Also the clunk will happen and the rpm's spike. See video. Any ideas before I tear into it?
      IMG_4791.mov
    • By Mudseeker149
      Just bought the atv, sounds like there’s sand in a bearing near the clutch! Any ideas?
