2000 arctic cat 300 4x4 rebuilding!!!
Ok so I'm back lol
I got two arctic cat 300s that I am either trying to make one of the two or if possible I'll get them both running. I have a good start but I am struggling to find a wiring diagram that actually shows the connections.
Both bikes were tore apart and some wiring was spliced and all screwed up so I have been tracing wires and redoing the connections.
On one bike I have a neutral light and it will let the use e start to turn starter motor, thing is on that bike the motor is stuck engaged so when I pull the pull cord it's turning the starter motor as well.
On the other bike it is free and works as it should but I can't get the neutral indicator light to come on. Or any for that matter. I have been going through the fuses which all have power as well as the e start switch.
I'm wondering if anyone has come across some similar issues, I am checking the neutral switch tonight, I have been checking the wiring and comparing it to the bike that is working (in that sense) but both bikes are missing some things
I'm wondering if it is a better option to pull the good motor out and rebuild it then put it into the bike with the indicator lights working. But on that bike all the bushings and linkages are toast so there's a lot of work to either bike. I'd like to at least get the engine to fire up before I invest too much energy into swapping motors.
So if anyone has some info or can send me in the direction of a good wiring diagram it would be much appreciated. Thanks
Just now, 97kingquad said:
Ok so I'm back lol
Are you saying starter motor is stuck? Did you try tapping on it with a hammer?  I believe that's it in the picture. Easy access, looks like you could take it off easily. I would start by making sure both motors turn over easily.
Edited by johniii
Yes I can get at it easy, I removed it and tested it. The starter itself is fine the issue is when you engage the starter it turns the motor then it should spin freely right? But when I turn the gears inside the hole they do not move individually. Like they are stuck together.
So when I use thepull cord to turn over the motor it is also turning the starter, the other bike doesn't have that issue
Update. I got the neutral indicator light to come on, and 1st needs a new bulb. Second works but the rest I assume are burnt out.
That being said I still have no power to the starter. So I am thinking the starter relay? I believe is what this is called. I'm assuming it is the culprit. Or the connections
What you have is a stuck or rusted over running clutch.  Refer to
2000 Arctic Cat 300 4X4 (RED) (A2000ATF4AUSR) Starter Clutch
Ebay has repair parts for $30.85 and up.  Blue LOCKTITE THOSE BOLTS!
Do yourself a favor and get the repair manual.
If you have power going to starter relay you have 12 volts on that post nothing on the other post, you hit the start button then get 12 volts on the post going to the starter if you still get nothing there, its either a bad relay or wiring from the switch. You can touch the two posts together with a screw driver and see if the starter turns.
    • By mga
    • By cavry
      Wiring shows White and Brown to solenoid blades. Then a black wire from starter circuit relay to solenoid. I am confused,  where is that black wire supposed to connect?
      Thanks for any help
      Cavry
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Its-always-something
    • By DarkRider
