By Rockbottom
any ideas how to correct
thanks ahead
By T37Mark
By hunky
This old boy has been coastal so lots of rust. But when I turn the key, nothing. Green neutral light works, head/tail lights work. Was running fine when I parked it for a few months.. no issues with starter. This did happen once before (last year).. not sure what overcame it.. maybe playing around with gear shifter.. but not sure if that was what did it. But doesn't seem to do anything now when I play around with it while hitting the start button.
I did take apart the handlebar mounted start button housing and looked it over. Couldn't figure anything out there, but looked the same as when I had the problem last year. Put my probes on various wires there but didn't learn anything.. not sure how it is wired.
So this first image there is a connector with 2 wires coming from forward (the male part of connector) - one blue and one blue w/ red stripe. The blue continues down to a post near where the gear shifter enters the housing. (Second image). I was wondering about that.. I opened up the connector and the 2 wires (coming from forward) show continuity when I put my probes on 'em. Thought that was weird, but maybe supposed to be like that? I turned on the key and tested for voltage but didn't find any.
I'm just unaware of how to test for anything. Would be interesting to put 12 volts to the starter, but not sure about doing that or how. The wires going in are kind of hard to get to. I suppose I could take out the starter.. but wanted to ask if there is something easier to check first.
Thanks for looking!
By Sha35297
I have this bike in my shop for a customer. It was sunk completely under water and left running until it killed. I did a complete engine rebuild. Replaced all bearings, crank, oil pump, and various other components. Engine starts and runs great. It will shift up through all gears perfectly in automatic and in ESP, but when slowing down it gets to 3rd gear and the MIL "-" light comes on and stays on. No flashes or anything and it will not shift gears. Kill the engine and restart in ESP mode and it is able to shift to neutral and start over. Does the same thing while down shifting in ESP mode. I replaced shift angle sensor with no improvement. Checked oil pressures as per repair manual "74psi" and higher with higher RPM's. With no MIL codes to point at an issue. I am at a loss as to what else to check or replace. Has anyone else ran across this issue?
